lm32 gdb core dumps
Jukka Pietarinen jukka.pietarinen at mrf.fi
Thu Apr 2 18:00:42 UTC 2009
I'm sorry - wrong alert - I accidentally ran bootstrap without the tools
in the path - now at least the sim is working...
Jukka
Jukka Pietarinen wrote:
> I'm spending time with the lm32 port again and it seems that nothing is
> working anymore (at least in the sim). I have traced down the problem up
> to a point where the heap is running into the stack. I'm confused
> because this happens during the call to
> rtems_initialize_data_structures() in shared bootcard.c
> I thought the heap wouldn't be initialized before a call to
> bootcatd_bsp_libc_helper, but I get several calls to
> _Heap_Block_allocate before that and the last call fails when the heap
> runs into the stack.
> On another issue: currently I'm unable to test this on hardware as the
> Lattice gdb does not work with the binaries produced with the
> lm32-rtems4.10 toolchain rpms and I have not managed get the toolchain
> gdb to talk to the JTAG hardware :(
> Thanks,
> Jukka
