Build now works, new failure.
Andrew Sporner
asporner at googlemail.com
Mon Apr 13 20:54:12 UTC 2009
Hi Joel,
> Do you see libmisc/shell/main_halt.c getting built?
> Do you see any mismatch in spelling grep'ing for halt in
> libmisc/shell? I don't and tested this.
Yes I did because I put a syntax error in the file to see if
the compiler would complain and it did. (lazy way, but it
works).
Not only that the symbol was in the library:
$ nm libshell.a | grep rtems_shell_HALT_Command
00000000 D rtems_shell_HALT_Command
U rtems_shell_HALT_Command
-- and --
> I expected that it was missed in the Makefile.am but it is
> there.
I noticed that too. I looked for an older command to compare
differences in how the stuff was showing (or not showing) up
and could find no differences, so frankly I was stuck.
>> wrote this probably would be a lot more efficient at this.
> Subtle hint. :)
Only subtle :-) [like a 2x4]. I will promise to do more independantly
as the learning curve comes down a bit. I am more used the the
BSD's and this approach is a little new to me.
I appreciate what ever kind of light you might be able to shine
on this.
Andy
PS. Once I get past this initial stuff, I would like to tackle the open
project about updating TCP/IP. This is one of my expert areas. I even
wrote a very simplified stack a few years ago.
