Build now works, new failure.
Andrew Sporner asporner at googlemail.com
Tue Apr 14 02:24:25 UTC 2009
Actually yes,
$ rpm -qa | grep rtems-4.10
rtems-4.10-binutils-common-2.19.1-1.suse10.3
rtems-4.10-newlib-common-1.17.0-33.suse10.3
rtems-4.10-powerpc-rtems4.10-gcc-4.3.3-11.suse10.3
rtems-4.10-apt-conf-0.20-1.suse10.3
rtems-4.10-gdb-common-6.8-10.suse10.3
rtems-4.10-powerpc-rtems4.10-binutils-2.19.1-1.suse10.3
rtems-4.10-powerpc-rtems4.10-gcc-c++-4.3.3-11.suse10.3
rtems-4.10-autoconf-2.63-2.suse10.3
rtems-4.10-gcc-common-4.3.3-12.suse10.3
rtems-4.10-powerpc-rtems4.10-cpukit-4.9.99.0.20090206.2-1.suse10.3
rtems-4.10-automake-1.10.2-2.suse10.3
rtems-4.10-powerpc-rtems4.10-gdb-6.8-10.suse10.3
rtems-4.10-powerpc-rtems4.10-newlib-1.17.0-32.suse10.3
and
$ echo $PATH
/opt/rtems-4.10/bin:/usr/lib/mpi/gcc/openmpi/bin:/home/asporner/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.
the examples I gave were a automatic reflex, but the
results are nearly the same:
$ powerpc-rtems4.10-nm libshell.a | grep HALT
00000000 D rtems_shell_HALT_Command
         U rtems_shell_HALT_Command
$ powerpc-rtems4.10-nm libshell_a-main_halt.o | grep HALT
Andy
