Hi Chris, Thanks! that worked!!! Andy On Mon, Apr 13, 2009 at 11:46 PM, Chris Johns <chrisj at rtems.org> wrote: > Andrew Sporner wrote: >> >> Actually yes, > > Please remove the cpukit rpm. It does not seem it can be installed when > building RTEMS samples and tests. > > This should fix the build. > > Regards > Chris >
