porting RTEMS to OpenSparc
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Aug 11 19:50:41 UTC 2009
Leontie Eugen wrote:
> Question in short : How difficult is it to port RTEMS to a really
> simple bsp based on the OpenSparc T1 processor ?
If you ignore the idea of distributing RTEMS threads onto the multiple
cores at first
and restrict yourself to a simple view of it as a single core CPU, you
will have to
deal with whatever SPARC architectural differences there are between the
V7 CPU
models currently supported and the V9 T1. This may result in having to
touch
the interrupt processing and context switch code. I really don't know
offhand.
A basic BSP with enough to run simple multithreaded code on and run
the RTEMS tests needs the following:
+ start - assembly code to initialize stack
+ hw initialization - board specific
+ clock tick - periodic interrupt to update time
+ console for debug output
Without knowing much, the V7 versus V9 differences will likely more
challenging
than the BSP itself.
One minor issue is that the current gcc tools only build v7 and v8
"multilib"
variants. v9 variants will have to be added. This from the gcc manual
hints
at some of the differences.
With `-mcpu=v9', GCC generates code for the V9 variant of the SPARC
architecture. This adds 64-bit integer and floating-point move
instructions, 3 additional floating-point condition code registers
and conditional move instructions. With `-mcpu=ultrasparc', the
compiler additionally optimizes it for the Sun UltraSPARC I/II/IIi
chips. With `-mcpu=ultrasparc3', the compiler additionally
optimizes it for the Sun UltraSPARC III/III+/IIIi/IIIi+/IV/IV+
chips. With `-mcpu=niagara', the compiler additionally optimizes
it for Sun UltraSPARC T1 chips. With `-mcpu=niagara2', the
compiler additionally optimizes it for Sun UltraSPARC T2 chips.
So the context has to support 64 bit registers and there are more
FP registers to deal with. The mips port already is an example of
sharing source between 32 and 64 bit variants so probably has guidance
for us.
> Question in details : My name is Eugen Leontie, I am a doctoral
> student at George Washington University. I want to use RTEMS as a
> target OS for a security enhanced processor architecture ( a MMU like
> structure that we are trying to develop - I will not go into details -
> I know RTEMS does not yet have virtual memory/security support, this
> is one of the reasons we chose it ). At this point I need to evaluate
> if it is feaseable to use RTEMS and I need some help from you. In
> order to get accurate cycle accurate performance measurements I need
> to get RTEMS to run one of Simics (http://www.virtutech.com/) target
> systems that supports Microarchitectural Simulations ( cycle accurate
> pipeline and caches simulations ). I found that there is a Leon2 port
> of Rtems that works with Simics
> http://www.cs.sfu.ca/~fedorova/Tech/simics-guides-3.0.26/simics-target-guide-leon2-simple.pdf
> <http://www.cs.sfu.ca/%7Efedorova/Tech/simics-guides-3.0.26/simics-target-guide-leon2-simple.pdf>
> , unfortunatelly the Leon target is pretty limited and can not support
> the features we need. The target we have in mind uses a SPARC
> processor, UltraSparc T1,
> http://www.cs.sfu.ca/~fedorova/Tech/simics-guides-3.0.26/simics-target-guide-niagara.pdf
> <http://www.cs.sfu.ca/%7Efedorova/Tech/simics-guides-3.0.26/simics-target-guide-niagara.pdf>
> that models very basically a Sun Fire T2000 server, it only has a
> console and RTC as modelled devices. It currently only works with an
> existing solaris image provided by the OpenSparc project. My question
> is how difficult ( in terms of time ) would it be to port RTEMS to the
> UltraSparc T1 based BSP ( a begginer versus a pro - as I need to
> estimate if I can use an undergraduate to this task or to contract a
> RTEMS speciallist just for this). And how valuable is to the RTEMS
> project such a port - I hope I can trade in this contribution to the
> RTEMS community and getting some forum/chat support getting this done
> . I am more than happy to provide additional details. Thank you in
> advance for your help. Eugen
One long term issue we would face as a project is testing. Is
there a free simulator that the BSP will be able to be tested on?
We are always happy to help by providing advice when someone wants to
port RTEMS to something new. I don't know how much general interest there
is in a T1 port but it is interesting. :)
