Executable size
Leon Pollak
leonp at plris.com
Wed Dec 23 15:25:09 UTC 2009
Hello, all.
I am trying to upgrade from 4.8.0 to 4.9.3.
After some small battles, I succeeded to have the working application - seems
to work as before upgrade.
The only problem is that the debug executable under debug RTEMS was 1,040KiB
while under 4.9.3 it is now... be brave :-) ... 4,520KiB. !!!
Studying the map file I did not see some rough major problem - the application
part is almost identical, but the system (compiler & rtems) part is so
different that I am not bale to follow the differences...:-(
Any hint will be highly appreciated.
Leon
