Executable size
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Dec 23 16:17:49 UTC 2009
On 12/23/2009 09:38 AM, Leon Pollak wrote:
> On Wednesday December 23 2009, Thomas Doerfler wrote:
>> Leon,
>> AFAIK the debug inforamtion added to the ELF file goes much more into
>> details now. So maybe this can be a reason. Are the 4.5Meg the ELF file
>> size or the code size? If it is the debug info, you may want to strip it
>> with *objcopy.
> This is what I meant - after objcpy I received 4.5MiB.
> I look also in the map file and see there these 4MiB size of text section
> only!
Just to confirm.. when you do size on it, the .text is 4.5 MB and
what was it before? I trust size. :)
If so, do you see any symbols which indicate subsystems which
are in the new one and not in the old one?
In general, applications should be smaller now. Maybe not a lot,
but some. So this is surprising. Debug information should be larger.
Real code should be smaller.
From here, we will need to:
+ compare map files for surprises
+ look at configuration (e.g. ../configure and your RTEMS configuration)
+how you link
--joel
> Thanks.
>> Merry Christmas,
>> Thomas.
>> Leon Pollak schrieb:
>>> Hello, all.
>>> I am trying to upgrade from 4.8.0 to 4.9.3.
>>> After some small battles, I succeeded to have the working application -
>>> seems to work as before upgrade.
>>> The only problem is that the debug executable under debug RTEMS was
>>> 1,040KiB while under 4.9.3 it is now... be brave :-) ... 4,520KiB. !!!
>>> Studying the map file I did not see some rough major problem - the
>>> application part is almost identical, but the system (compiler& rtems)
>>> part is so different that I am not bale to follow the differences...:-(
>>> Any hint will be highly appreciated.
