Executable size
Alexandre Constantino alexandre.constantino at edisoft.pt
Wed Dec 23 17:01:32 UTC 2009
Hello,
Just to make sure: if you run *objdump -h EXECUTABLE, you get a .text section with 4.5MiB instead of 1.0MiB?
This is farfetched... but are you (either your application or RTEMS with custom build flags) using any exotic options?
Maybe -O0, -O3, -funroll-loops, -finline-functions?
Sorry I can't be much help with this.
Regards,
Alexandre
On Wednesday 23 December 2009, Leon Pollak wrote:
> On Wednesday December 23 2009, Thomas Doerfler wrote:
> > Leon,
> > AFAIK the debug inforamtion added to the ELF file goes much more into
> > details now. So maybe this can be a reason. Are the 4.5Meg the ELF file
> > size or the code size? If it is the debug info, you may want to strip it
> > with *objcopy.
> This is what I meant - after objcpy I received 4.5MiB.
> I look also in the map file and see there these 4MiB size of text section
> only!
> Thanks.
> > Merry Christmas,
> > Thomas.
> > Leon Pollak schrieb:
> > > Hello, all.
> > > I am trying to upgrade from 4.8.0 to 4.9.3.
> > > After some small battles, I succeeded to have the working application -
> > > seems to work as before upgrade.
> > > The only problem is that the debug executable under debug RTEMS was
> > > 1,040KiB while under 4.9.3 it is now... be brave :-) ... 4,520KiB. !!!
> > > Studying the map file I did not see some rough major problem - the
> > > application part is almost identical, but the system (compiler & rtems)
> > > part is so different that I am not bale to follow the differences...:-(
> > > Any hint will be highly appreciated.
