Executable size
Sebastian Huber
Wed Dec 23 18:09:08 UTC 2009
Hi,
you may have a look at this:
http://www.rtems.org/ml/rtems-users/2009/september/msg00126.html
The problem is fixed with the recent GCC 4.4 snapshot.
Merry Christmas and a Happy New Year!
Sebastian
Leon Pollak wrote:
> Hello, all.
> I am trying to upgrade from 4.8.0 to 4.9.3.
> After some small battles, I succeeded to have the working application - seems
> to work as before upgrade.
> The only problem is that the debug executable under debug RTEMS was 1,040KiB
> while under 4.9.3 it is now... be brave :-) ... 4,520KiB. !!!
> Studying the map file I did not see some rough major problem - the application
> part is almost identical, but the system (compiler & rtems) part is so
> different that I am not bale to follow the differences...:-(
> Any hint will be highly appreciated.
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
