ARM SAM9 BSP Question
Enrico Lüdecke
enrico.luedecke at gmx.de
Mon Feb 2 10:46:00 UTC 2009
Hi all,
I am working on a BSP for an ARM SAM9 board. At the moment I try to
understand the interrupt handling of the board itself and the RTEMS part
of it. There is a macro in arm/rtems/score/cpu.h called _CPU_ISR_Enable
I don't fully understand:
#define _CPU_ISR_Enable( _level ) \
asm volatile ("MSR cpsr, %0 \n" \
: : "r" (_level)); \
(Just write the content of %0 to the current program status register)
If I leave it in that way, the interrupts aren't enabled as it seems. If
I change it to:
int reg; \
asm volatile ("MRS %0, cpsr \n" \
"BIC %1, %0, #0xc0\n" \
"MSR cpsr, %1 \n" \
: "=&r" (_level), "=&r" (reg));\
(save the cpsr, clear the IRQ and FIQ mask bit, write it back to cpsr)
the interrupts are enabled and all seems to work well. I use a copy of
RTEMS 4.8. In older versions, the code looked more like mine, but now it
doesn't anymore. My question is: Where do I put my working code? Since
I'm writing a BSP, cpu.h seems to be the wrong place.
Please excuse me, if my question is kind of dumb, but I just started
looking over this whole stuff.
Regards
Enrico
