BDI-2000 was Re: Internal_errors_What_happened = 18? (RTEMS_CALLED_FROM_ISR)
Greg.Marsden at l-3com.com
Mon Feb 2 14:27:47 UTC 2009
We use BDI2000/3000s with the MPC8260 and Virtex 4/5 PPCs and they work
well.
We run powerpc-rtems4.x-gdb under ddd to take advantage of the GUI
interface.
If you use "monitor load" rather than "load", it uses tftp and is much
faster.
- Greg
Leon Pollak wrote:
> On Monday February 2 2009, Joel Sherrill wrote:
>> If I remember this all correctly, the BDI-2000 speaks regular
>> gdb remote protocol. You can use the powerpc-rtems gdb
>> binary and connect something like this:
>> target remote IP:PORT
>> You might want to do a "load" command to get the image
>> to the target.
>> But this should be in your bdi documentation. Perhaps someone
>> with one currently setup can be of more direct use.
> I am working just now with BDI2000 on MPC8260.
> Yes, Joel, you are right.
> I will be glad to help, if I can.
