Possible bug in FAT dir listing
Chris Johns
chrisj at rtems.org
Fri Feb 6 00:08:35 UTC 2009
Gene Smith wrote:
> This also explains why a volume label shows up as a file in rtems when
> doing ls. It should be ignored too.
The issue was different.
> AFAICT, there is no code in the rtems FAT library to ignore files when
> these attribute flags are set. I only see the "directory" attribute
> checked in some places.
I have added the code to fix this and will check it in sometime in the future
when other changes I have are working.
Regards
