BOOTP and MVME5500
Robert Varner
varnerrl at ornl.gov
Mon Feb 9 17:51:08 UTC 2009
I recently upgraded to 4.9.1 and discovered that my MVME5500 would no
longer BOOTP. After some research, I discovered that the "bsp.h" file
had been set to choose the Gigabit ethernet interface, a change
from the earlier version I was using (4.7). However, even after
I changed connections, the module still fails to hear the BOOTP response
from my server. If I modify "bsp.h" to select the 10/100 ethernet
interface on the MVME5500, it can successfully BOOTP.
Can anyone suggest what I should do to successfully use the Gigabit
ethernet interface on the MVME5500 with RTEMS 4.9.1?
Robert Varner
