Obscure udp multicast issue/bug
Gene Smith gds at chartertn.net
Mon Feb 16 21:21:18 UTC 2009
Gene Smith wrote:
> When I send to a multicast address with TTL set to 1 (default, restrict
> m/c to local subnet) and my gateway is set to NULL or to an invalid
> address, I get destination unreachable (errno = 118) on sendto() call.
> It fails in ip_output() before it even checks that the destination
> address is multicast.
> So if I want to multicast on only my local subnet and there is no
> configured router/gateway to the outside world, I still have to specify
> a reachable host as the gateway to get multicast to work.
> I don't know if this is expected behavior or something broken in the BSD
> stack.
> -gene
See bug 1381 for proposed fix.
