Weird problem on rs232 vs USB-serial...
mike
antispam21 at verizon.net
Mon Feb 23 19:32:21 UTC 2009
Thanks Steven,
One more addition is:
- if I use 'grmon' to connect to the DSU port, then load the same app
with grmon and run,
I can see outputs coming out of the COM1 port.
- it was when I used the onboard bootrom to load the app to ram, then
jump to it that I didn't
see any outputs on COM1 port. Again, when it's connected to
USB<->serial, the outputs
came out fine, with the same app.
Anything else I need to look? Thanks again.
-mike-
Steven Grunza wrote:
> My first suggestion would be to use a Voltmeter to measure the Voltage
> on the PC's COM1. Assuming a DB9 connection you should see -5V or more
> between pins 3 and 5. If you have a DB25 then check between pins 2 and
> 7.
> Back in the old days (before Maxim's MAX232 and similar chips) it wasn't
> unusual for a cheap RS-232 interface to "steal" negative Voltage power
> from the other end of the connection. This usually worked well unless
> the data rate was too high or the other end was also trying to "steal"
> negative Voltage power. I know of some Tandy machines that used this
> trick.
> The USB part probably uses either a Maxim or other vendor's RS-232
> interface powered from the 5V available on the USB interface.
> That's it for my USD 0.02
>> -----Original Message-----
>> From: rtems-users-bounces at rtems.org
>> [mailto:rtems-users-bounces at rtems.org] On Behalf Of mike
>> Sent: Monday, February 23, 2009 2:03 PM
>> To: RTEMS Users
>> Subject: Weird problem on rs232 vs USB-serial...
>> Hi all,
>> We have a Leon2-based board using the RTEMS leon2 BSP. The
>> host is x86 running CentOS 2.6.
>> With a simple application that outputs to /dev/console for
>> stdio (printf):
>> - with the board connected directly to COM1 of the host, no
>> output is seen
>> - with the board connected to a USB<->serial adapter
>> (Keyspan), outputs and inputs were fine
>> * This is with the same app initializing the UART to 38400,
>> 8N1, no flow control.
>> * On the host, we just use 'minicom' set for 38400, 8N1, no
>> flow control
>> (/dev/ttyS1 in the 1st case and /dev/ttyUSB0 in the 2nd case)
>> What could possibly be the cause?
>> Thanks for any comments/pointers.
>> -mike-
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20090223/7564c7bf/attachment.html>
