ANN: lm32-rtems4.10 toolchain rpms
Wed Feb 25 14:01:52 UTC 2009
Thanks.
The gdb executable at least now loads an RTEMS application. :-D
Jon.. when you run gdb or -run do you pass any
special arguments?
When I do a "tar sim; load; run", hello.exe fails like this:
Starting program:
/home/joel/rtems-4.10-work/build/build-lm32-lm32_evr-rtems/lm32-rtems4.10/c/lm32_evr/testsuites/samples/hello/hello.exe
core: 4 byte read to unmapped address 0x800001c at 0x800001c
There is no readme for the BSP so it could easily be
an operator error on my part at this point.
--joel
Ralf Corsepius wrote:
> Joel Sherrill wrote:
>> Speedy. :)
>> I successfully built the CVS head for lm32/lm32_evr.
>> Is the lm32 gdb in your queue?
> I had added a vanilla gdb-upstream based lm32-rtems4.10-gdb package
> yesterday, but ... as you had experienced ... upstream gdb is still
> lacking support for the lm32, so these packages had been non-functional :(=)
> Anyway, ... thanks to Jon B.'s (original author of the lm32 parts of the
> GNU toolchain) assistance, we now should have a fully up2date
> lm32-rtems4.10-gdb.
> I merged Jon's latest version of his patches, adapted them for gdb-cvs
> HEAD and made them buildable ...
>> It has a simulator for this BSP?
> Meanwhile, yes (except for MinGW - MinGW doesn't provide the necessary
> APIs to be able to build the simulator)
> Of course, I don't know if its functional. However, this gdb consists of
> the very latest bits and pieces from both upstream FSF gdb and Jon, so
> this is the max. you can get ;)
>> It didn't install with yum install "*lm32*"
> Try again, ...
> Ralf
