lm32 timer
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Feb 26 20:40:57 UTC 2009
Hi,
hello and ticker now run on the simulator. But
the timer tests do not. They fail with this:
*** TIME TEST 1 ***
core: 4 byte write to unmapped address 0x8000a008 at 0x800171c
Apparently I need a timer1 at 0x8000A000.
How do I configure a second timer with
the simulator?
If not possible is this two instantiations of
the same hardware module and we could just use
timer0 again since you don't need the clock
driver and timer driver at the same time?
