lm32 timer
Jukka Pietarinen
jukka.pietarinen at mrf.fi
Fri Feb 27 08:27:24 UTC 2009
Joel Sherrill wrote:
> hello and ticker now run on the simulator. But
> the timer tests do not. They fail with this:
> *** TIME TEST 1 ***
> core: 4 byte write to unmapped address 0x8000a008 at 0x800171c
> Apparently I need a timer1 at 0x8000A000.
> How do I configure a second timer with
> the simulator?
> If not possible is this two instantiations of
> the same hardware module and we could just use
> timer0 again since you don't need the clock
> driver and timer driver at the same time?
When writing the BSP I was not aware that you do not need both
simultaneously. I think one could change the benchmark timer to use the
CPU cycle counter instead of a timer instance but you would loose
overflow detection although I doubt it will matter with a 32 bit counter.
Jukka
