Telnetd initialization changes
Sebastian Huber
Fri Feb 27 09:29:35 UTC 2009
Hi,
I would like to change the telnetd initialization routine to avoid dependencies
with the DES code for password checks. The password check and DES code use in
total 70464 bytes of global data (a bit to much if you only have 128kB RAM).
typedef bool (*rtems_telnetd_password_check)(const char *);
rtems_status_code rtems_telnetd_initialize(
void (*cmd)(char *, void *),
void *arg,
bool remainOnCallerSTDIO,
size_t stack,
rtems_task_priority priority,
rtems_telnetd_password_check check
check == NULL => no password check
I would also like to change the return value from 'int' to 'rtems_status_code'.
Have a nice day!
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
