rtems_region_create, and starting_memory address.
Sebastian Huber
Wed Feb 4 14:23:29 UTC 2009
Nick Thomas wrote:
> OK,
> Thanks for that, good idea.
> So, now I have a static array declared of a certain size, and I can use that
> in the call to rtems_region_create.
Is it a global array or on the stack?
> But, now I get a crash almost immediately after a reset, it's an
> INTERNAL_ERROR_CORE, with the_error=5.
When is immediately after reset? Before the region create or afterwards? What
completed before the error. Which BSP?
> According to my sources, this means
> INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL.
> How do I enlarge my interrupt stack?
I guess the problem is not the interrupt stack.
> Regards
> Nick
>> -----Original Message-----
>> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Sent: 04 February 2009 14:01
>> To: Nick Thomas
>> Cc: rtems-users at rtems.com
>> Subject: Re: rtems_region_create, and starting_memory address.
>> Sebastian Huber wrote:
>>> Nick Thomas wrote:
>>>> Is there a BSP non-specific way of obtaining the first unused memory
>>>> address?
>>> malloc()
>> You can also allocate memory during link time if you create an array of
>> your desired region size and create at runtime a region managing the
>> space of this array.
>> Sebastian Huber, Embedded Brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone : +49 89 18 90 80 79-6
>> Fax : +49 89 18 90 80 79-9
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> rtems-users mailing list
