rtems_bsdnet_fdToSocket()
Till Straumann
strauman at slac.stanford.edu
Fri Feb 13 00:17:29 UTC 2009
Chris Johns wrote:
> Joel Sherrill wrote:
>> Till Straumann wrote:
>>>>> IMHO rtems_bsdnet_fdToSocket() doesn't
>>>>> verify thoroughly enough that the file
>>>>> descriptor passed in is really a socket.
>>>>> If you e.g., try getsockname() on a fd
>>>>> that was opened on a termios device then
>>>>> a crash may result.
>>>>> I propose to let rtems_bsdnet_fdToSocket()
>>>>> test not only that iop->data1 is NULL but
>>>>> to add an additional test.
>>>>> Either
>>>>> 1) add a new flag LIBIO_FLAGS_ISSOCK
>>>>> which is set by rtems_bsdnet_makeFdForSocket()
>>>>> and tested by rtems_bsdnet_fdToSocket()
>>>>> 1a) instead of one flag we could use a few
>>>>> more bits and create a LIBIO_FLAGS_IOP_TYPE
>>>>> bitmask (in case the need for other special
>>>>> cases besides sockets arises in the future).
>>>>> The test would then look like
>>>>> if ( LIBIO_FLAGS_IOP_TYPE(iop->flags) !=
>>>>> LIBIO_FLAGS_IOP_TYPE_SOCK ) {
>>>>> errno = ENOTSOCK;
>>>>> return NULL;
>>>>> Sidenote: IMO, if data1 == NULL then errno should
>>>>> also be ENOTSOCK instead of EBADF.
>>>> The LIBIO flags do not describe the fd rather they deal with what
>>>> you can do. I do not like the type of fd being added to the flags.
>>>> NetBSD has a type field in the fp referenced by the fd:
>>> Problemo being that libio has no such thing. It has
>>> absolutely no knowledge about what is attached to
>>> 'data', 'data1', 'file-info'.
>>> Where do you see an equivalent to fp_type in the iop
>>> or how would you propose that, given a iop, the
>>> code can figure out what kind of object
>>> is attached to e.g., 'data1' ?
> I am suggesting we add a type field.
OK - then we're on the same page. I thought you didn't like the idea of
knowledge about a file type built into a 'iop'. If the type is encoded
in 'flags' or in a dedicated field doesn't matter too much, IMHO since
it would be accessed via a macro or inline, i.e., the user setting or
querying the type wouldn't have to know how/where is is kept.
rtems_libio_iop_set_type(iop, type)
type rtems_libio_iop_get_type(iop)
> This makes the way we test common and does not depend on the way the
> other fields in the struct are used. I see the other ways as possible
> maintenance issues. That is the tests for a specific type cannot
> overlap and all need to be in a common location. Making the test
> common is even better, ie check the type field. This is a limited
> number of types.
> Again NetBSD has:
> $ less sys/sys/file.h
> * Kernel descriptor table.
> * One entry for each open kernel vnode and socket.
> struct file {
> LIST_ENTRY(file) f_list; /* list of active files */
> int f_flag; /* see fcntl.h */
> int f_iflags; /* internal flags */
> #define DTYPE_VNODE 1 /* file */
> #define DTYPE_SOCKET 2 /* communications endpoint */
> #define DTYPE_PIPE 3 /* pipe */
> #define DTYPE_KQUEUE 4 /* event queue */
> #define DTYPE_MISC 5 /* misc file descriptor type */
> #define DTYPE_CRYPTO 6 /* crypto */
> #define DTYPE_NAMES \
> "0", "file", "socket", "pipe", "kqueue", "misc", "crypto"
> int f_type; /* descriptor type */
> I also like the iflags field. If we make a change to add fields I
> would like the iflags field added.
>>> Do you like testing the 'handlers' better?
> No. It exposes the lower layers to the upper layers and means more
> globals.
I couldn't agree more.
> There could also be other complexity like something having more than
> one possible set of handlers. The DOSFS has this for dir and file
> handlers.
Agreed, again.
T.
>> Looking at libcsupport/src/libio_socket.c, that's the only
>> thing you can currently rely on.
>> Might not be a bad generic check. Worth a libio macro
>> like rtems_libio_handlers_match?
> It mixes layers. What handlers do you need to match with.
> Regards
> Chris
>> --joel
>>> T.
>>>> int
>>>> getsock(struct filedesc *fdp, int fdes, struct file **fpp)
>>>> struct file *fp;
>>>> if ((fp = fd_getfile(fdp, fdes)) == NULL)
>>>> return (EBADF);
>>>> FILE_USE(fp);
>>>> if (fp->f_type != DTYPE_SOCKET) {
>>>> FILE_UNUSE(fp, NULL);
>>>> return (ENOTSOCK);
>>>> *fpp = fp;
>>>> return (0);
>>>> I would prefer this.
>>>> Regards
>>>> Chris
>>>>> 2) alternatively, rtems_bsdnet_fdToSocket() could
>>>>> test if iop->handlers == socket_handlers.
>>>>> socket_handlers would then have to become a globally
>>>>> visible symbol (right now a static variable).
>>>>> Unfortunately, this would introduce some asymmetry
>>>>> (fdToSocket() refers to global symbol, makeFdForSocket
>>>>> gets pointer to handlers passed in).
>>>>> If nobody objects or has a better idea then I would
>>>>> implement 1a), create a PR and commit to 4.9 and HEAD.
>>>>> RFC
>>>>> -Till
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
