Weird problem on rs232 vs USB-serial...
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 23 19:43:09 UTC 2009
mike wrote:
> Thanks Steven,
> One more addition is:
> - if I use 'grmon' to connect to the DSU port, then load the same app
> with grmon and run,
> I can see outputs coming out of the COM1 port.
> - it was when I used the onboard bootrom to load the app to ram, then
> jump to it that I didn't
> see any outputs on COM1 port. Again, when it's connected to
> USB<->serial, the outputs
> came out fine, with the same app.
Could the flow control settings be wrong in the comm application when
using the ttys0?
I recall that minicom on unix defaults to HW flow control on.
> Anything else I need to look? Thanks again.
> -mike-
> Steven Grunza wrote:
>> My first suggestion would be to use a Voltmeter to measure the Voltage
>> on the PC's COM1. Assuming a DB9 connection you should see -5V or more
>> between pins 3 and 5. If you have a DB25 then check between pins 2 and
>> 7.
>> Back in the old days (before Maxim's MAX232 and similar chips) it wasn't
>> unusual for a cheap RS-232 interface to "steal" negative Voltage power
>> from the other end of the connection. This usually worked well unless
>> the data rate was too high or the other end was also trying to "steal"
>> negative Voltage power. I know of some Tandy machines that used this
>> trick.
>> The USB part probably uses either a Maxim or other vendor's RS-232
>> interface powered from the 5V available on the USB interface.
>> That's it for my USD 0.02
>>> -----Original Message-----
>>> From: rtems-users-bounces at rtems.org
>>> [mailto:rtems-users-bounces at rtems.org] On Behalf Of mike
>>> Sent: Monday, February 23, 2009 2:03 PM
>>> To: RTEMS Users
>>> Subject: Weird problem on rs232 vs USB-serial...
>>> Hi all,
>>> We have a Leon2-based board using the RTEMS leon2 BSP. The
>>> host is x86 running CentOS 2.6.
>>> With a simple application that outputs to /dev/console for
>>> stdio (printf):
>>> - with the board connected directly to COM1 of the host, no
>>> output is seen
>>> - with the board connected to a USB<->serial adapter
>>> (Keyspan), outputs and inputs were fine
>>> * This is with the same app initializing the UART to 38400,
>>> 8N1, no flow control.
>>> * On the host, we just use 'minicom' set for 38400, 8N1, no
>>> flow control
>>> (/dev/ttyS1 in the 1st case and /dev/ttyUSB0 in the 2nd case)
>>> What could possibly be the cause?
>>> Thanks for any comments/pointers.
>>> -mike-
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
