ANN: lm32-rtems4.10 toolchain rpms
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 23 20:34:41 UTC 2009
Speedy. :)
I successfully built the CVS head for lm32/lm32_evr.
Is the lm32 gdb in your queue? It has a simulator for this BSP?
It didn't install with yum install "*lm32*"
--joel
Ralf Corsepius wrote:
> Hi,
> I am pleased to announce that I've added lm32-rtems4.10 toolchain rpms
> to RTEMS yum repositories.
> This toolchain consists of
> * Yesterday's binutils-cvs snapshot (aka. binutils-2.19.51 20090222)
> * gcc-4.3.3/newlib-1.17.0 + a set of patches, which consists of a
> back-port of the lm32.patch pending for inclusion to gcc-4.4.0, rtems
> specific additions missing in upstream GCC's patch and a bug fix in
> newlib's lm32 support.
> Those of you who already use rtems.org's yum repository:
> yum install rtems-4.10-lm32-rtems4.10-gcc
> installs these packages
> Those preferring to manually download the RPMs, please c.f.
> ftp://ftp.rtems.org/pub/rtems/linux/4.10
> Source tarballs are available in
> ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10
> Note:
> To be able to use lm32-* toolchains with RTEMS, you _must update_ your
> RTEMS source-tree's toplevel _config.sub_ to a very recent version of
> config.sub.
> The versions being shipped with FSF automake-1.10.2 or older is _not_
> sufficient. rtems-4.10-automake >= 1.10.2-2 has been updated to supply a
> suiteable version.
> The low level way to do so:
> yum install rtems-4.10-automake
> cp /opt/rtems-4.10/share/automake/config.sub <rtems-4.10-sourcedir>/
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
