ANN: lm32-rtems4.10 toolchain rpms
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Feb 23 17:20:04 UTC 2009
Hi,
I am pleased to announce that I've added lm32-rtems4.10 toolchain rpms
to RTEMS yum repositories.
This toolchain consists of
* Yesterday's binutils-cvs snapshot (aka. binutils-2.19.51 20090222)
* gcc-4.3.3/newlib-1.17.0 + a set of patches, which consists of a
back-port of the lm32.patch pending for inclusion to gcc-4.4.0, rtems
specific additions missing in upstream GCC's patch and a bug fix in
newlib's lm32 support.
Those of you who already use rtems.org's yum repository:
yum install rtems-4.10-lm32-rtems4.10-gcc
installs these packages
Those preferring to manually download the RPMs, please c.f.
ftp://ftp.rtems.org/pub/rtems/linux/4.10
Source tarballs are available in
ftp://ftp.rtems.org/pub/rtems/SOURCES/4.10
Note:
To be able to use lm32-* toolchains with RTEMS, you _must update_ your
RTEMS source-tree's toplevel _config.sub_ to a very recent version of
config.sub.
The versions being shipped with FSF automake-1.10.2 or older is _not_
sufficient. rtems-4.10-automake >= 1.10.2-2 has been updated to supply a
suiteable version.
The low level way to do so:
yum install rtems-4.10-automake
cp /opt/rtems-4.10/share/automake/config.sub <rtems-4.10-sourcedir>/
Ralf
