RTEMS/QEMU/GRUB on Windows
Massimo Tipaldi
mtipaldi at cgspace.it
Wed Jan 7 10:03:52 UTC 2009
Dear all,
first of all, I wish you all the best for this year.
I am still trying to work RTEMS on Windows. I have followed all the
advices from Joel and Chris (Rtems 4.9.1 with the related examples and
RTEMS tools 4.9).
For what concerns the RTEMS installation:
1) with the option "--enable-multilib", the installation fails
(libnetworking/netinet/.deps/libnetworking_a-if_ether.Po: No such file
or directory);
2) without the option "--enable-multilib", the installation was
successfully.
Are there any differences with the option --enable-multilib? Can I
configure RTEMS without this option?
For what concerns the compilation and execution of Hello_Word via QEMU,
the issues described in my previous emails remain(see my previous emails
for more details: the only difference is that RTEMS is now installed in
d:\opt\src\rtems\i386\):
1) I have to modify the Makefile.inc
(d:\opt\src\rtems\i386\i386-rtems4.9\c\pc386\make)
2) I have to create the two variables RTEMS_MAKEFILE_PATH and ARCH
3) I have to copy start16.bin into the folder d:/msys1.0/lib
Even though the hello.exe is created, it is not correctly managed by
QEMU (the "No multiboot header found" message appears).
What I can further add, is that the dimension of my Hello Word is 17 Kb,
whereas the dimension of the Hello Word that comes from the RTEMS
compliation (correctly run by QEMU)is about 1 Mb.
Why should I modify the Makefile.inc? Why is not sufficient to set the
RTEMS_MAKEFILE_PATH variable (as stated in RTMES manuals)? How can I
produce a Hello Word application manageable by QEMU?
Joel, what does it means that the file hello.ralf should have had
bin2boot run on it? Should QEMU run somehow this file, instead of
hello.exe? If yes, how?
Thanks in advance
Massimo
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute in questo messaggio di posta elettronica
e relativi allegati sono riservate e confidenziali e ne e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system. Please do not copy it or use it for any
purposes, or disclose its contents to any other person: to do so could
be a breach of confidence. Thank you for your co-operation. Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
