Need sources for libc
Simon Edelhaus
Shimon at Centillium.com
Wed Jan 7 15:12:17 UTC 2009
We are using RTEMS 4.6.0-prel3 for MIPS 4KC. Tools and libc version:
Reading specs from /opt/rtems/lib/gcc-lib/mips-rtems/3.2.1/specs
Configured with: ../gcc-3.2.1/configure
--build=i686-pc-linux-gnu --host=i686-pc-linux-gnu
--target=mips-rtems -- with-gnu-as --with-gnu-ld
--with-newlib --verbose --with-system-zlib --disable-nls
--enable-version-specific- runtime-libs
--enable-threads=rtems --prefix=/opt/rtems
--enable-languages=c,c++,ada Thread model: rtems gcc version
3.2.1 (OAR Corporation gcc-3.2.1-20021209/newlib-1.11.0-20030203 2)
From inside libc.a :
../../gcc-3.2.1/newlib/libc/stdlib/strtod.c^
@/home/rtems/src/packages/BUILD/mips-rtems-gcc
-newlib/build/mips-rtems/newlib/libc/stdlib/
^@../../../../../gcc-3.2.1/newlib
/libc/stdlib/strtod.c^@gcc2_compiled
We have a nasty crash in our application. We get:
assertion "0" failed: file "../../../.
Unfortunately CPU dies before we get a chance to see the
file and line number.
We think this assertion printout is coming from the "libc.a".
We only have the object.
Where do we get the sources for this, to modify the string
to be much shorter to get the file and line number printout
for above assertion? And how do we rebuild "libc.a" correctly?
Thanks in advance for any help.
Thank you very much!
Ttfn,
Simon Edelhaus
Transwitch 2009
