AV5282 Network driver
frank.ueberschar at dsa-volgmann.de frank.ueberschar at dsa-volgmann.de
Thu Jan 8 11:33:54 UTC 2009
To whom it may concern,
we are using parts of the network driver from
the AV5282 BSP with our own BSP-Code. We have
enountered Problems when transmitting fragmented
IP Packets (i.e. send ICMP Ping with high amount
of dataload).
We think that we might have found a bug in that
code in network.c so someone please could verify that.
(We still work on rtems-4.5.1 - nevertheless :-))
If in the fec_sendpacket(..) an IP Fragment mbuffer
with zero length if(m->m_len) occurs then this packet
will be put on the mbuf chain, however. This will
result in used buffer descriptors that will never
be freed again.
In our opinion/experience the following patch resolves
this problem:
*** network-orig.c Thu Jan  8 12:04:21 2009
--- network.c Thu Jan  8 12:06:05 2009
*************** fec_sendpacket(struct ifnet *ifp, struct
*** 548,557 ****
    * The IP fragmentation routine in ip_output
    * can produce fragments with zero length.
-   txBd = sc->txBdBase + sc->txBdHead;
    if (m->m_len){
     char *p = mtod(m, char *);
     int offset = (int) p & 0x3;
     if (offset == 0) {
      txBd->buffer = p;
      txBd->length = m->m_len;
--- 548,557 ----
    if (m->m_len){
+    txBd = sc->txBdBase + sc->txBdHead;
     if (offset == 0) {
      txBd->buffer = p;
Best regards,
Frank Ueberschar
DSA-Volgmann
Thomas Volgmann
Redcarstr. 20
53842 Troisdorf
Tel:    02241 23416 16
Fax:    02241 23416 666
email : frank.ueberschar at dsa-volgmann.de
web:    www.dsa-volgmann.de
URL: <http://lists.rtems.org/pipermail/users/attachments/20090108/51543171/attachment.html>
