Possible bug in libchip/i2c/spi-sd-card.c (my MMC/SD problem)
Fri Jan 16 00:20:02 UTC 2009
Gene Smith wrote:
> I don't have a way to check or verify this right now but I may see the
> reason for the problem I am having doing shell copies on my MMC cards.
> In my previous email
> http://www.rtems.com/ml/rtems-users/2009/january/msg00078.html
> I mentioned that 4 sectors (flash blocks) were written sequentially that
> should have been scattered about in flash. Only the first one was at the
> right place (the first FAT entry).
> Also in this email, before I had a clue as to what I was seeing, I
> reported 4 multiple blocks being written on file copy and the last
> contained the copied file data:
> data:http://www.rtems.com/ml/rtems-users/2009/january/msg00040.html
> In both cases I think I am seeing the same thing.
> The multiple block write occurs in spi-sd-card.c in function
> sd_card_disk_block_write(..., r) where prm r is a struct/array of
> scattered buffers (each at a random address). There are 4 block to be
> written at address 0x200 (main FAT), 0x1ec0 (redundant FAT), 0x3d600
> (root dir entry) and 0x41600 (cluster 2 with file data). Since there are
> 4 buffers (r->bufnum > 1) in the scatter array, a multiple block write
> to MMC/SD is selected. The multiple write sets the starting address to
> the first block (0x200) and writes all 4 blocks back to back beginning
> at that address, which is wrong in this case. That's why my blocks end
> up in the FAT area instead of at the right place.
> So, unless the blocks are known to be truly sequential and not scattered
> or random, only then should the multiple blocks method be used. I don't
> know if there is a way to know without parsing the scatter array each
> time. So it might be better (but slower) to always just use single block
> write method multiple times if bufnum > 1.
Does the driver set the multi-sector continuous flag when the cache asks for
capabilities ?
The driver in CVS has the code in 'sd_card_disk_ioctl':
	case RTEMS_BLKDEV_CAPABILITIES:
  		*((uint32_t*) arg)  = RTEMS_BLKDEV_CAP_MULTISECTOR_CONT;
  		return 0;
If this is being set and you are getting sectors that are not continuous I
would like to know.
Regards
> Again, this is a theory that has yet to be verified.
> -gene
> rtems-users mailing list
> rtems-users at rtems.com
