Possible bug in libchip/i2c/spi-sd-card.c [Finally works!]
Gene Smith gds at chartertn.net
Fri Jan 16 04:52:34 UTC 2009
Gene Smith wrote, On 01/15/2009 10:47 PM:
<snip>
> 	} else if (req == RTEMS_BLKDEV_CAPABILITIES) {
> 		/* causes bdbuf to only do single block writes to flash */
<snip>
The comment should actually say:
		/* allows multiple SD/MMC block writes to occur only when block
numbers are sequential. Otherwise single block writes occur. */
I originally thought only single block writes would occur.
