RTEMS/QEMU/GRUB on Windows
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jan 8 16:42:13 UTC 2009
Massimo Tipaldi wrote:
> Joel,
> from your email, I have understood that I have generated my hello.exe
> correctly and that the "No multiboot header found" message is due to an
> format incompatibility between my hello.exe and the grub.
> Can you confirm this?
hello.exe is an ELF
hello.ralf is netboot
I thought Grub could boot ELF files.
What Grub can or cannot boot is unknown to me.
> After compiling RTEMS (target=i386-rtems4.9 and RTEMS_BSP=”pc386”),
> I have carried out the following steps to configure QEMU/GRUB(taken from
> http://www.rtems.com/wiki/index.php/QEMU):
> 1) From the RTEMS wiki, download the following files: qemu.bat,
> rtems-boot.img e rtems-grub.cfg
> 2)Copy the file rtems-boot.img in d:\opt\rtems-4.9
> 3)Copy the file qemu.bat in d:\opt\rtems-4.9
> 4) Copy the file rtems-grub.cfg in
> /d/opt/src/rtems/i386/i386-rtems4.9/c/pc386/testsuites/samples
> 5)Modify the file qemu.bat as follows:
> rem @echo off
> set QEMU=D:\opt\rtems-4.9\qemu-0.9.0-windows
> %QEMU%\qemu -L %QEMU% -m 128 -boot a -fda
> d:\opt\rtems-4.9\rtems-boot.img -hda fat:%1 %2 %3
> 6) In d:\opt\rtems-4.9, launch the batch file batch rtems.bat
> 7) In the DOS shell launch the QEMU virtual machine as follows: qemu
> d:\opt\src\rtems\i386\i386-rtems4.9\c\pc386\testsuites\samples
> 8)The GRUB is being launched: choose the application to start from the
> configured menu
> As previously written, the hello.exe produced during the RTEMS
> compilation is correctly booted from QEMU/GRUB. Unfortunately, this does
> not happen with my hello.exe.
> Can you suggest me a way to make compatible Grub with my hello.exe? How
> can I make my hello.exe an ELF file?
> Can you confirm me that I have installed QEMU correctly?
> Which ralf files are you referring to? The hello.ralf that comes from my
> compilation?
> Massimo
>>> Dear all,
>>> first of all, I wish you all the best for this year.
>>> I am still trying to work RTEMS on Windows. I have followed all the
>>> advices from Joel and Chris (Rtems 4.9.1 with the related examples and
>>> RTEMS tools 4.9).
>>> For what concerns the RTEMS installation:
>>> 1) with the option "--enable-multilib", the installation fails
>>> (libnetworking/netinet/.deps/libnetworking_a-if_ether.Po: No such file
>>> or directory);
>>> 2) without the option "--enable-multilib", the installation was
>>> successfully.
>>> Are there any differences with the option --enable-multilib? Can I
>>> configure RTEMS without this option?
>>> For what concerns the compilation and execution of Hello_Word via
>>> QEMU, the issues described in my previous emails remain(see my
>>> previous emails for more details: the only difference is that RTEMS is
>>> now installed in d:\opt\src\rtems\i386\):
>>> 1) I have to modify the Makefile.inc
>>> (d:\opt\src\rtems\i386\i386-rtems4.9\c\pc386\make)
>>> 2) I have to create the two variables RTEMS_MAKEFILE_PATH and ARCH
>>> 3) I have to copy start16.bin into the folder d:/msys1.0/lib
>>> Even though the hello.exe is created, it is not correctly managed by
>>> QEMU (the "No multiboot header found" message appears).
>>> What I can further add, is that the dimension of my Hello Word is 17
>>> Kb, whereas the dimension of the Hello Word that comes from the RTEMS
>>> compliation (correctly run by QEMU)is about 1 Mb.
>> My ".ralf" files are reported as this by file:
>> http://www.rtems.org/wiki/index.php/BoardSupportPackageInformation#PowerPC_BSPs
>> What about yours?
>> What are you booting RTEMS from? How did you create your grub
>>> Why should I modify the Makefile.inc? Why is not sufficient to set the
>>> RTEMS_MAKEFILE_PATH variable (as stated in RTMES manuals)?
>> If you can build the example/hello, then it is OK and there
>> is just a discrepancy between the executable format produced
>> and how you are booting it (grub version, setup, etc?)
>>> How can I produce a Hello Word application manageable by QEMU?
>>> Joel, what does it means that the file hello.ralf should have had
>>> bin2boot run on it?
>> bin2boot converts it to a netboot image. I do not know the
>> relationship between that and a multiboot image.
>>> Should QEMU run somehow this file, instead of hello.exe? If yes, how?
>> I am running ELF files from a qemu vfat. I use the .exe files.
>>> Thanks in advance
>>> Massimo
