Rtems for a space project
Massimo Tipaldi
mtipaldi at cgspace.it
Tue Jan 13 08:12:31 UTC 2009
OK, I experienced myself that the Rtems makefiles are not correct ...but
I should solve my issue, if it is possible.
In any case, I'd like to know if:
1) someone has considering compiling an easy RTEMS application on
Windows PC for i386(and not on a Linux PC, where I konw that it works)
2) how this application can be make compliant with Grub (Elf
file/multiboot specification).
I insist on these points:
1) the Grub set-up is correct and the source of this failure is
somewhere else (the hello.exe in testsuites/samples works)
2) I have followed all the Rtems wiki instructions to install the
toolchains, rtems and so on; the packages have been downloaded following
the links shown on Rtems wiki.
Can I hope to solve this issue? Is Rtems today mature for Windows?
Massimo
rtwas ha scritto:
> Hello,
> Ralf Corsepius wrote:
>> Makefile.inc is a different class of problem.
>> My personal answer to all Makefile.inc related problems: I refuse to
>> answer any Makefile.inc related issues, because I consider RTEMS
>> Makefile-template system to be mal-designed kid-stuff, RTEMS should
>> have stopped dropped a long time ago ;)
> I was never comfortable with having the make-system *hidden* from me. I made
> an attempt to be a *good boy* and use it but couldn't get it to work for
> my particular
> build so I ended up reverse engineering it (Makefile templates etc.) and
> writing my
> own (Makefile system) from scratch.
> Robert W.
> rtems-users mailing list
> rtems-users at rtems.com
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute in questo messaggio di posta elettronica
e relativi allegati sono riservate e confidenziali e ne e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system. Please do not copy it or use it for any
purposes, or disclose its contents to any other person: to do so could
be a breach of confidence. Thank you for your co-operation. Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
