Rtems for a space project
Massimo Tipaldi mtipaldi at cgspace.it
Tue Jan 13 14:48:20 UTC 2009
Joel,
I have downloaded QEMU from http://www.h7.dion.ne.jp/~qemu-win/.
The file is qemu-0.9.0-windows.zip.
Window version of QEMU: 0.9.0
GNU GRUB version 1.94
Massimo
Joel Sherrill ha scritto:
> Massimo Tipaldi wrote:
>> OK, I experienced myself that the Rtems makefiles are not correct
>> ...but I should solve my issue, if it is possible.
> I have been unable to duplicate any problem you have reported.
> I don't know what is going wrong with your install.
>> In any case, I'd like to know if:
>> 1) someone has considering compiling an easy RTEMS application on
>> Windows PC for i386(and not on a Linux PC, where I konw that it works)
> It works on Windows but the main developers use Windows
> as little as possible.  The Eclipse plugin work was initially
> done on Windows.
>> 2) how this application can be make compliant with Grub (Elf
>> file/multiboot specification).
> You have at least 4 variables.  I suspect your qemu/grub
> setup.  Can you tell me where you got your Windows version
> of Qemu and what version it is.  The one I see is not that latest
> version and that by itself is enough to cause issues.
> With that, I will run the executable and grub setup I have
> on Linux on Windows so we can be sure that a known good
> RTEMS executable can even run on the version of qemu
> you have.
> I do LOTS of testing on qemu/rtems/grub/linux.  This is
> how the i386-rtems tool test results are generated.  That is
> ~80K tests in batch mode.  There are many Windows users.
> So we need to reduce variables.  First order is to split it
> between rtems/tools and qemu.
>> I insist on these points:
>> 1) the Grub set-up is correct and the source of this failure is
>> somewhere else (the hello.exe in testsuites/samples works)
>> 2) I have followed all the Rtems wiki instructions to install the
>> toolchains, rtems and so on; the packages have been downloaded
>> following the links shown on Rtems wiki.
>> Can I hope to solve this issue? Is Rtems today mature for Windows?
>> Massimo
>> rtwas ha scritto:
>>> Hello,
>>> Ralf Corsepius wrote:
>>>>  Makefile.inc is a different class of problem.
>>>>  My personal answer to all Makefile.inc related problems: I refuse to
>>>>  answer any Makefile.inc related issues, because I consider RTEMS
>>>>  Makefile-template system to be mal-designed kid-stuff, RTEMS should
>>>>  have stopped dropped a long time ago ;)
>>> I was never comfortable with having the make-system *hidden* from me.
>>> I made
>>> an attempt to be a *good boy* and use it but couldn't get it to work
>>> for my particular
>>> build so I ended up reverse engineering it (Makefile templates etc.)
>>> and writing my
>>> own (Makefile system) from scratch.
>>> Robert W.
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
