Rtems for a space project
Sebastian Huber
Wed Jan 14 14:06:43 UTC 2009
Massimo Tipaldi wrote:
> I have analysed the makefiles inside the tree
> (testsuites/samples/hello), what an effort...
I tried it once and it was a nightmare. Fortunately it is not needed if you
only want to figure out the tool options for a particular BSP. Just use a
Makefile that does this for you (like the one I have posted previously).
> I have noticed this definition (used in i386-rtems4.9-gcc):
> GCCSPECS = -B$(PROJECT_ROOT)/lib/ -specs bsp_specs -qrtems
> I have tried to adapt the Makefile.inc in this way:
If the standard make facility does not work something with your RTEMS tools or
MinGW/MSYS installation or BSP configuration is wrong. There is no need to dig
into the *.inc and *.cfg files. This will not help you in the long run.
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
