Rtems for a space project
Massimo Tipaldi mtipaldi at cgspace.it
Wed Jan 14 14:35:21 UTC 2009
Sebastian,
how can integrate your Makefile with yours?
My makefile is (taken form Rtems examples4.9.1):
PGM=${ARCH}/hello.exe
# optional managers required
MANAGERS=all
# C source names
CSRCS = test.c
COBJS = $(CSRCS:%.c=${ARCH}/%.o)
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(PROJECT_ROOT)/make/leaf.cfg
OBJS= $(COBJS) $(CXXOBJS) $(ASOBJS)
all:    ${ARCH} $(PGM)
$(PGM): $(OBJS)
     $(make-exe)
Massimo
Sebastian Huber ha scritto:
> Massimo Tipaldi wrote:
>> I have analysed the makefiles inside the tree
>> (testsuites/samples/hello), what an effort...
> I tried it once and it was a nightmare.  Fortunately it is not needed if you
> only want to figure out the tool options for a particular BSP.  Just use a
> Makefile that does this for you (like the one I have posted previously).
>> I have noticed this definition (used in i386-rtems4.9-gcc):
>> GCCSPECS =  -B$(PROJECT_ROOT)/lib/ -specs bsp_specs -qrtems
>> I have tried to adapt the Makefile.inc in this way:
> If the standard make facility does not work something with your RTEMS tools or
> MinGW/MSYS installation or BSP configuration is wrong.  There is no need to dig
> into the *.inc and *.cfg files.  This will not help you in the long run.
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
