Possible bug in FAT dir listing
Gene Smith
gds at chartertn.net
Wed Jan 14 15:39:59 UTC 2009
Till Straumann wrote:
> Not sure - I vaguely recall encountering a similar problem
> (w/o using your 'ls' command). Could this be related to PR#1273 ?
> T.
Didn't see your patch from a year ago when I first looked at pr#1273. I
will try it this evening. Looks like it will block the bad file names
that display with attribute 0xf. However, think it should also skip it
if just the volume label bit is set (since I see volume labels display
as files with ls too).
Thanks!
-gene
