Possible bug in FAT dir listing
Gene Smith
gds at chartertn.net
Wed Jan 14 19:13:35 UTC 2009
Chris Johns wrote:
> I think the FAT code is ok rather I suspect this is a result of the ls
> command's handling of the attributes for the directory. Could you please file
> a PR with RTEMS bugzilla ? I ported this command from Unix and it must have
> some issues.
> Regards
> Chris
Probably beating a dead horse but found this old 2006 post (probably
pre-shell?) regarding bad files listed with a leading "A":
http://www.rtems.com/ml/rtems-users/2006/july/msg00099.html
