SOLVED -- Rtems for a space project:
Massimo Tipaldi mtipaldi at cgspace.it
Thu Jan 15 10:40:08 UTC 2009
Hi Chris,
good news. I have managed to compile Rtems and Hello World on Windows.
QEMU boots my hello.exe correctly.
Thanks for your inputs. I'll keep informed the Rtems community for what
concerns its usage for the on-board SW of the ESA satellite.
Being able to use Rtmes in Windows could be a further valid reason for
its choice.
Thanks again.
Massimo
Chris Johns ha scritto:
> Hi Massimo,
> I have headed back to the start of the thread to see if we can correct
> the impression this thread may have made and to get you sorted out. I am
> sorry about the delay in getting something concrete to work with and to
> test with.
> Massimo Tipaldi wrote:
>> In any case, it would have been nice to use RTEMS with a Windows host,
>> but it seems so far that it is not possible. Executable files compiled
>> on a Windows host are not compatible with the elf/multiboot
>> specifications (surely for what we have seen in the last weeks).
> This statement is incorrect. The tools work correctly and build for the
> pc586 target correctly and further boot as a multiboot image with qemu.
>> Moreover, it would be even nice to me
>> 1) to write down this issue and to try to solve it in the next RTEMS
>> versions or,
>> 2) if it is somehow already possible, to show the steps to generate a
>> RTEMS application on a Windows host in an ELF format.
> I assume a correctly set up MinGW and MSYS with an updated M4. I then
> downloaded:
>  http://www.rtems.org/ftp/pub/rtems/windows/4.9/build-5/rtems4.9-tools-5.exe
> and ran it and installed the i386 tools. I then downloaded:
>  http://www.rtems.org/ftp/pub/rtems/4.9.1/rtems-4.9.1.tar.bz2
> then opened an RTEMS Tools window. I did this from the Start menu and
> the RTEMS 4.8 menu. There is an entry called RTEMS Tools. This is a
> specially set up Windows Command shell (cmd.exe). In the shell I ended
> up at:
>  c:\opt\rtems-4.9
> I then:
>  cd ..
>  mkdir src
>  cd src
>  mkdir rtems
>  cd rtems
>  mkdir 4.9
>  cd 4.9
>  tar jxf /c/downloads/rtems/rtems-4.9.1.tar.bz2
> Please note you may need to vary the path to the RTEMS source code
> depending on where you downloaded it. I then configured, built and
> installed RTEMS:
>  mkdir i386
>  cd i386
>  sh ../rtems-4.9.1/configure --target=i386-rtems4.9 --enable-rtemsbsp=pc586
>  make
>  make install
> I then went to this page in the documentation:
> http://www.rtems.org/onlinedocs/releases/rtemsdocs-4.9.1/share/rtems/html/started/started00063.html
> and set the variable in the RTEMS Tools Windows Command shell:
>  set RTEMS_MAKEFILE_PATH=c:\opt\rtems-4.9\i386-rtems4.9\pc586
> I then download the examples:
>  http://www.rtems.org/ftp/pub/rtems/4.9.1/examples-4.9.1.tar.bz2
> unpacked them and built hello:
>  mkdir examples
>  tar jxf /c/downloads/rtems/examples-4.9.1.tar.bz2
>  cd examples-4.9.1\hello_world_c
>  make
> This created a 'o-optimize\hello.exe' and I could run this with my qemu
> set up  detailed here:
>  http://www.rtems.org/wiki/index.php/QEMU
> Using the qemu.bat file and once at the grub prompt I entered:
>  multiboot (hd0,0)/o-optimize/hello.exe
>  boot
> and hello world ran and completed.
> Please try this and let me know how it goes.
> Regards
> Chris
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
