Another DOS Format issue with MMC/SD [Fixed]
Gene Smith
gds at chartertn.net
Wed Jan 28 15:40:26 UTC 2009
Gene Smith wrote:
> In cpukit/libfs/src/dosfs/msdos_format.c function dos_format() I added
> dd->start to every place the sector number is used and it seemed to fix
> the problem. The sector numbers in dos_format() were all zero based so
> all writes started at the 0th sector, overwriting the MBR.
When I back port the HEAD version of spi-sd-card.c to 4.9.1 discussed in
http://www.rtems.org/bugzilla/show_bug.cgi?id=1356
I don't need to change msdos_format.c. That is because the new HEAD
version sets up all writes to SD/MMC card to go through the cache/block
layer which adds in dd->start automatically. Writes to absolute sectors
are not done.
> But when I look at the formatted card on linux, df says it is 1% used
> but gparted says it it 42% used with one small file on it. Blocks look
> reasonable with dd. Sectors per cluster was originally 4 (OEM
> formatting) now it is 2. Total number of sector in f/s is 65,537. With
> 512 bytes per sector that is only 33M while the device with OEM
> formatting showed about 60M I think. ??? :(
> When reformatted in linux df shows 56068 1K blocks. gparted show
> slightly more probably includes boot rec, fats and root.
> dd shows 4 sectors per cluster (same as OEM format),
> dd shows 112,392 sectors in the fs, same as gparted starting a sector 63
> (start of boot rec).
> Print to rtems syslog of card's CSD data at startup shows
> Block size [B] 512
> Block number 127232 <--- Linux only uses 112392 of these! ??
> Capacity [B] 65142784
> So something is still not quite right in rtems dos_format() or somewhere
> else in the way it is setting the boot record.
This problem still exists in 4.9.1 even with the new HEAD version of
spi-sd-card.c. But I found the reason and fix described here:
http://www.rtems.org/bugzilla/show_bug.cgi?id=1363
