Another DOS Format issue with MMC/SD [Fixed]
Thu Jan 29 15:12:40 UTC 2009
Since you have filed PRs for both of these.  If you
will attach diffs to both of them, I will commit to
both 4.9 and the head as appropriate.
Thanks.
--joel
Gene Smith wrote:
> Gene Smith wrote:
>> In cpukit/libfs/src/dosfs/msdos_format.c function dos_format() I added
>> dd->start to every place the sector number is used and it seemed to fix
>> the problem. The sector numbers in dos_format() were all zero based so
>> all writes started at the 0th sector, overwriting the MBR.
> When I back port the HEAD version of spi-sd-card.c to 4.9.1 discussed in
> http://www.rtems.org/bugzilla/show_bug.cgi?id=1356
> I don't need to change msdos_format.c. That is because the new HEAD
> version sets up all writes to SD/MMC card to go through the cache/block
> layer which adds in dd->start automatically. Writes to absolute sectors
> are not done.
>> But when I look at the formatted card on linux, df says it is 1% used
>> but gparted says it it 42% used with one small file on it. Blocks look
>> reasonable with dd. Sectors per cluster was originally 4 (OEM
>> formatting) now it is 2. Total number of sector in f/s is 65,537. With
>> 512 bytes per sector that is only 33M while the device with OEM
>> formatting showed about 60M I think.  ??? :(
>> When reformatted in linux df shows 56068 1K blocks. gparted show
>> slightly more probably includes boot rec, fats and root.
>> dd shows 4 sectors per cluster (same as OEM format),
>> dd shows 112,392 sectors in the fs, same as gparted starting a sector 63
>> (start of boot rec).
>> Print to rtems syslog of card's CSD data at startup shows
>> Block size [B] 512
>> Block number 127232     <--- Linux only uses 112392 of these! ??
>> Capacity [B] 65142784
>> So something is still not quite right in rtems dos_format() or somewhere
>> else in the way it is setting the boot record.
> This problem still exists in 4.9.1 even with the new HEAD version of
> spi-sd-card.c. But I found the reason and fix described here:
> http://www.rtems.org/bugzilla/show_bug.cgi?id=1363
> rtems-users mailing list
> rtems-users at rtems.com
