RTEMS on Mistral OMAP35x EVM board
xu ray rayx.cn at gmail.com
Fri Jan 30 11:18:54 UTC 2009
No BSP available for cortex family yet. Currently only Thumb and ARM port is
ready. BTW, the tool chain for cortex family has not been tested yet (the
latest 4.10 tool chain should have the support for cortex ).
You will have to change the code in score related to  ISR and context swap
from ARM assembly code to thumb-2 code. The rest should be the same as add a
normal BSP.
2009/1/28 Steven Grunza <grunza at ulticom.com>
> This board has a TI OMAP35x CPU.  It's either a OMAP3503, OMAP3515,
> OMAP3525, or an OMAP3530.  Looks like the big difference between the
> CPU's is graphics support (none/2D/3D) and DSP support.
> The core of the OMAP35x is a Cortex-A8 ARM.  For more info on this board
> you can look at
> http://focus.ti.com/general/docs/gencontent.tsp?contentId=36917
> Is anyone working on a BSP for this board?  If not does anyone have a
> suggestion as to where to begin?  I'm still working on an H8SX port and
> I'm low on round tuits but I only have access to this hardware for a
> limited time...
> "Unix is user friendly, it's just  Steven Grunza
> particular about with whom it      voice: (856) 787 - 2759
> makes friends."                    fax:   (856) 866 - 2033
> - Unknown                          mailto:grunza at ulticom.com
>                                   flames:/dev/null
> rtems-users mailing list
> rtems-users at rtems.com
Thanks & Best Regards!
Ray, Xu
URL: <http://lists.rtems.org/pipermail/users/attachments/20090130/07cb8c3d/attachment-0001.html>
