Multiprocessor problems
Daniel Hellstrom daniel at gaisler.com
Wed Jul 1 13:14:03 UTC 2009
Hello,
The init task name is defined by confdef.h, it is possible to set the
init task name to a custom name using the CONFIGURE_INIT_TASK_NAME
define, for example:
#define CONFIGURE_INIT_TASK_NAME          rtems_build_name('U', 'I',
'0'+CONFIGURE_MP_NODE_NUMBER, ' ')
Perhaps a patch is not needed in this case?
Daniel
Joel Sherrill wrote:
> Provide a patch and I will merge it. :)
> --joel
> Daniel Hellstrom wrote:
>> Hi,
>> On a similar MP topic, all Init tasks have the same name "UI1"
>> regardless of CPU node. I have seen in the mptests that the
>> CONFIGURE_INIT_TASK_ATTRIBUTES is set to RTEMS_GLOBAL, this means
>> that the rtems_ident_task() can not be used to look up the ID of the
>> remote node's Init task. Perhaps the Init task name could be
>> {'U','I','0'+nodeid,'\0'} instead?
>> GRMON thread info output from the two LEON3 CPUs, CPU0
>> [0x40000000-0x43FFFFFF0] and CPU1 [0x44000000-0x47FFFFFF0]:
>> grlib> sym rtems-mp1
>> read 1456 symbols
>> entry point: 0x40000000
>> grlib> thread info
>>   Name | Type     | Id         | Prio | Time (h:m:s)  | Entry
>> point             | PC                                           | State
>>   Int. | internal | 0x09010001 |  255 |      0.000000 |
>> _BSP_Thread_Idle_body   | 0x400030a4 _BSP_Thread_Idle_body +
>> 0x0       | READY
>>   Int. | classic  | 0x09010002 |    0 |      0.005648 |
>> _MPCI_Receive_server    | 0x4000c66c _Thread_Dispatch +
>> 0xd8           | Wsem
>> * UI1  | classic  | 0x0a010001 |    1 |      0.000000 |
>> Init                    | 0x40001368 Init +
>> 0x4                        | READY
>> grlib> sym rtems-mp2
>> read 1456 symbols
>> entry point: 0x44000000
>> grlib> thread info
>> point             | PC                                           | State
>>   Int. | internal | 0x09020001 |  255 |      0.000000 |
>> _BSP_Thread_Idle_body   | 0x440030a4 _BSP_Thread_Idle_body +
>> 0x0       | READY
>>   Int. | classic  | 0x09020002 |    0 |      0.005661 |
>> _MPCI_Receive_server    | 0x4400c66c _Thread_Dispatch +
>> 0xd8           | Wsem
>> * UI1  | classic  | 0x0a020001 |    1 |      0.000000 |
>> Init                    | 0x40001368 _RAM_SIZE +
>> 0x3c00136c            | READY
>> Daniel
>>> Hi,
>>> The problem seems to be the initialization of _Objects_Local_node in
>>> multiprocessor enabled kernels. Since the _MPCI_Initialization()
>>> initializes _Objects_Local_node later than the first semaphores and
>>> tasks are created, this makes the IDs assigned to created objects
>>> incorrect.
>>> In single processor systems the _Objects_Local_node is a constant
>>> set to 1, but in multiprocessor systems it is initially set to zero
>>> and then initialized by _MPCI_Initialization().
>>> The problem you experience is probably the same problem I ran into
>>> this week when running on a dual core SPARC/LEON3 system. Two tasks
>>> are created before the node number is setup correctly. See below
>>> print out
>> >from GRMON after breaking at Init():
>>> grmon> thread info
>>> point             | PC                                           |
>>> State
>>>  Int. | internal | 0x09000001 |  255 |      0.000000 |
>>> ??               | 0x0           | READY
>>>  Int. | classic  | 0x09000002 |    0 |      0.000000 | ??
>>>                | 0x0              | Wsem
>>> RAM_END                 | 0x40001368 Init +
>>> 0x4                        | READY
>>> As you can see the node number is 0 rather than 1 or 2 in the ID field.
>>> The bug appears when the first MPCI packet is received on the target
>>> node, the ISR calls _MCPI_Announce which tries to release a
>>> semaphore, the blocked thread are thought to be global and the
>>> system crashes. The function deciding if it is a global or local
>>> object simply checks if they are of the same node, not if the node
>>> number is zero.
>>> RTEMS_INLINE_ROUTINE bool _Objects_Is_local_node(
>>>  uint32_t   node
>>>  return ( node == _Objects_Local_node );
>>> To test that this theory holds I changed the declaration of
>>> _Objects_Local_node to extern instead of SCORE_EXTERN, and declared
>>> it in my project initialy initialized to the node number. The LEON3
>>> dual core system now works and I have successfully managed to get
>>> semaphores and tasks interacting between the two nodes.
>>> uint16_t _Objects_Local_node = CONFIGURE_MP_NODE_NUMBER;
>>> I suggest that the initialization of _Objects_Local_node is moved to
>>> be initialized earlier.
>>> Regards,
>>> Daniel Hellstrom
>>>> Roger Dahlkvist wrote:
>>>>> Hi,
>>>>> I'm using a timer ISR polling method checking for new messages
>>>>> from other nodes. Unfortunately the system crashes as soon as
>>>>> rtems_multiprocessing_announce is called.
>>>> There are no interrupts enabled until the initialization task is
>>>> switched
>>>> in.
>>>> I have wondered if it wouldn't make sense to have the MP
>>>> initialization
>>>> sycnhronization done either explicitly by the application (like
>>>> initialization
>>>> of TCP/IP) or implicitly by the init thread like C++ global
>>>> constructors.
>>>> You can try moving this code from exinit.c to threadhandler.c where
>>>> and
>>>> protect it somehow from being executed more than once.
>>>> #if defined(RTEMS_MULTIPROCESSING)
>>>>   if ( _System_state_Is_multiprocessing ) {
>>>>     _MPCI_Initialization();
>>>>     _MPCI_Internal_packets_Send_process_packet(
>>>>       MPCI_PACKETS_SYSTEM_VERIFY
>>>> #endif
>>>> Then you will at least be able to get your interrupts and call MP
>>>> announce
>>>> to complete system initialization.
>>>>> However, rtems_multiprocessing_announce works just fine if it's
>>>>> called just after the initialization phase, before the
>>>>> initinitialization task is started. That's really strange.
>>>>> So for example, if I make one node get initialized and started
>>>>> faster than the other node (using less drivers etc), I'll be able
>>>>> to create global objects. and as long as the other node has not
>>>>> started the initialization task, the message is received and the
>>>>> global objects table is updated, so it can be identified later on.
>>>>> But I can't use them since furter calls to
>>>>> rtems_multiprocessing_announce will fail.
>>>>> At this point I feel like I have tested just about everything,
>>>>> with no luck. It's urgent that I get MP to work properly. I'm
>>>>> using Nios II processors and I have defined my own MPCI routines.
>>>>> I'm confident that they work properly and I have verified that the
>>>>> system crashes before they are even invoked.
>>>>> Is there anyone with MP experience who might have a clue of what's
>>>>> causing my problems? Any help is MUCH appreciated.
>>>>> //Roger
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
