RFC: Interrupt Manager Extension changes
Sebastian Huber
Fri Jul 10 12:04:25 UTC 2009
Hi,
the Interrupt Manager Extension is documented here:
http://www.rtems.com/doxygen/cpukit/html/group__rtems__interrupt__extension.html
In order to support the legacy API and FreeBSD interrupt handlers better I
would like to change the interrupt handler signature from
typedef void (*rtems_interrupt_handler)(rtems_vector_number, void *);
to
typedef void (*rtems_interrupt_handler)(void *);
The current signature was primarily chosen to support the Classic API in the
future without overhead. This turned out to be impractical.
I would also like to change the return code for requests with an invalid vector
number from RTEMS_INVALID_NUMBER to RTEMS_INVALID_ID since the vector number
acts like an object ID in this context.
I would like to add a new API for interrupt handlers which should be executed
within a task context:
* @brief Initializes the interrupt server task.
* The task will have the priority @a priority, the stack size @a stack_size,
* the modes @a modes and the attributes @a attributes. Interrupt handlers can
* be installed on the server with rtems_interrupt_server_handler_install() and
* removed with rtems_interrupt_server_handler_remove(). In case of an
* interrupt the request will be forwarded to the server. The handlers are
* executed within the server context. If one handler blocks on something this
* may delay the processing of other handlers.
* @note This function may block.
* @return
* - On success @c RTEMS_SUCCESSFUL shall be returned.
* - If the interrupt server task is already initialized
* @c RTEMS_INCORRECT_STATE shall be returned.
* - Other error states are BSP specific.
rtems_status_code rtems_interrupt_server_initialize(
rtems_task_priority priority,
size_t stack_size,
rtems_mode modes,
rtems_attribute attributes
* @brief Installs the interrupt handler routine @a handler for the interrupt
* vector with number @a vector.
* The handler routine will be executed on the interrupt server task.
* @see rtems_interrupt_handler_install().
* @return
* - If the interrupt handler server is not initialized
* - For other errors see rtems_interrupt_handler_install().
rtems_status_code rtems_interrupt_server_handler_install(
rtems_vector_number vector,
const char *info,
rtems_option options,
rtems_interrupt_handler handler,
void *arg
* @brief Removes the interrupt handler routine @a handler with argument @a arg
* for the interrupt vector with number @a vector.
* @see rtems_interrupt_handler_remove().
* @return
* - For other errors see rtems_interrupt_handler_remove().
rtems_status_code rtems_interrupt_server_handler_remove(
void *arg
Have a nice day!
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
