[GSOC2009] Skyeye shutdown device patch for 1.2.8 branch of SKYEYE
xi yang
hiyangxi at gmail.com
Sat Jul 11 05:27:34 UTC 2009
Index: device/nandflash/nandflash_smallblock.c
--- device/nandflash/nandflash_smallblock.c (revision 691)
+++ device/nandflash/nandflash_smallblock.c (working copy)
@@ -516,7 +516,7 @@
#endif
nf->writebuffer=(u8*)malloc(dev->pagedumpsize);
//nf->memsize=528*32*4096;
- if ((nf->fdump= open(dev->dump, FILE_FLAG)) < 0)
+ if ((nf->fdump= open(dev->dump, FILE_FLAG, FILE_MODE)) < 0)
free(nf);
printf("error open nandflash dump!\n");
Index: device/nandflash/nandflash_smallblock.h
--- device/nandflash/nandflash_smallblock.h (revision 691)
+++ device/nandflash/nandflash_smallblock.h (working copy)
@@ -27,6 +27,8 @@
#define FILE_FLAG (O_RDWR | O_CREAT)
#endif
+#define FILE_MODE (0x777)
#if (defined(__MINGW32__) || defined(__BEOS__))
#define POSIX_SHARE_MEMORY_BROKEN
#endif
Index: memory/ram.c
--- memory/ram.c (revision 691)
+++ memory/ram.c (working copy)
@@ -261,10 +261,10 @@
void * state;
switch(size){
case 8:
- *(uint8_t *)value = (uint8_t)mem_read_byte (offset);
+ *value = (uint8_t)mem_read_byte (offset);
break;
case 16:
- *(uint16_t *)value = (uint16_t)mem_read_halfword(offset);
+ *value = (uint16_t)mem_read_halfword(offset);
break;
case 32:
*value = mem_read_word(offset);
Index: arch/arm/common/armemu.c
--- arch/arm/common/armemu.c (revision 691)
+++ arch/arm/common/armemu.c (working copy)
@@ -676,7 +676,15 @@
io_do_cycle (state);
state->NumInstrs++;
+ if (skyeye_config.shutdown_device.status){
+ if (skyeye_config.shutdown_device.max_ins){
+ if (state->NumInstrs >= skyeye_config.shutdown_device.max_ins){
+ fprintf(stderr, "Shutdown_device:max_ins expired\n");
+ exit(2);
#ifdef MODET
/* Provide Thumb instruction decoding. If the processor is in Thumb
mode, then we can simply decode the Thumb instruction, and map it
@@ -5069,6 +5077,11 @@
MEM_STORE_LOG("WORD");
BUSUSEDINCPCN;
+ if(skyeye_config.shutdown_device.status){
+ if(address == skyeye_config.shutdown_device.shutdown_addr)
+ exit(0);
#ifndef MODE32
if (DESTReg == 15)
state->Reg[15] = ECC | ER15INT | R15PC | EMODE;
Index: utils/config/skyeye_config.h
--- utils/config/skyeye_config.h (revision 691)
+++ utils/config/skyeye_config.h (working copy)
@@ -100,6 +100,21 @@
} machine_config_t;
+ * If status of shutdown device is 1, when "shutdown_addr"
+ * (align on 8bytes) is written, SKYEYE simulator exits.
+ * If the number of executed instructions by skyeye simulator
+ * is bigger than "max_instructions", then skyeye return with
+ * value 2
+typedef struct shutdown_config
+ unsigned int status;
+ u32 shutdown_addr;
+ unsigned long long max_ins;
+}shutdown_config_t;
#define MAX_BANK 8
#define MAX_STR 1024
@@ -183,6 +198,7 @@
int do_dummy_option ();
int do_arch_option ();
int do_cpu_option ();
+int do_shutdown_option ();
int do_mach_option ();
int do_mem_bank_option ();
int do_net_option ();
@@ -248,6 +264,7 @@
//mem_config_t mem;
//chy 2003-09-12, now support more io banks
// ioaddr_config_t ioaddr; //used for ARMul_notIOaddr funciton
+ shutdown_config_t shutdown_device;
net_config_t net[NET_MAXNICNUM_PER_HOST];
uart_config_t uart;
log_config_t log;
@@ -280,10 +297,12 @@
{"arch", do_arch_option, 0, 1},
{"cpu", do_cpu_option, 0, 1},
{"mach", do_mach_option, 0, 1},
+ {"shutdown_device", do_shutdown_option,0, 1},
/*mem option */
{"mem_bank", do_mem_bank_option, 0, MAX_BANK},
{"net", do_net_option, 0, 10},
{"energy", do_energy_option, 0, 1},
{"uart", do_uart_option, 0, MAX_UART_DEVICE_NUM},
Index: utils/config/skyeye_options.c
--- utils/config/skyeye_options.c (revision 691)
+++ utils/config/skyeye_options.c (working copy)
@@ -79,6 +79,9 @@
config->uart.count = 0;
atexit(skyeye_uart_cleanup);
+ config->shutdown_device.status = 0;
+ config->shutdown_device.max_ins = 0;
/*ywc 2005-04-01 */
config->no_dbct = 1; /*default, dbct is off */
//teawater add for new tb manage function
2005.07.10----------------------------
@@ -247,6 +250,44 @@
int
+do_shutdown_option (skyeye_option_t * this_option, int num_params,
+ const char *params[])
+ int ret;
+ char *value;
+ shutdown_config_t *shutdown = &(skyeye_config.shutdown_device);
+ if(ret = strncmp(params[0],"addr=",5)){
+ SKYEYE_ERR ("Error, Wrong parameter for shutdown_device\n");
+ return -1;
+ value = &(params[0][5]);
+ if(value[0]=='0' && (value[1] == 'x' || value[1] == 'X'))
+ shutdown->shutdown_addr = (unsigned int)strtoul(value,NULL,16);
+ else
+ shutdown->shutdown_addr = (unsigned int)strtoul(value,NULL,10);
+ if(shutdown->shutdown_addr & 0x7){
+ SKYEYE_ERR ("Error, shutdown address needs align on 8 bytes\n");
+ return -1;
+ if(ret = strncmp(params[1],"max_ins=",8)){
+ return -1;
+ value = &(params[1][8]);
+ shutdown->max_ins = strtoull(value,NULL,16);
+ else
+ shutdown->max_ins = strtoull(value,NULL,10);
+ shutdown->status = 1;
+ printf("Shutdown addr=%x,
max_ins=%x\n",shutdown->shutdown_addr,shutdown->max_ins);
+ return 1;
+int
do_mem_bank_option (skyeye_option_t * this_option, int num_params,
