C compiler cannot create executables
Martin Grim
W.M.Grim at sron.nl
Tue Jul 28 11:11:59 UTC 2009
Hi,
> - did you already install the proper binutils first?
This seemed to be the problem: the binutils, etc. where installed after the configure was run. Now that I've changed the order, everything build oke.'
Thanks for the hint.
Martin
ir. W.M. Grim
SRON Netherlands Institute for Space Research
Sorbonnelaan 2
3584 CA Utrecht, The Netherlands
www.sron.nl
