RTEMS use of Linux specific errno's
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Jun 11 18:42:32 UTC 2009
Hi,
newlib cvs has moved EBADRQC and which
is used by various files in /cpukit/libblock/src
and some libchip drivers and ENOTBLOCK which is
used by the fatfs to inside an ifdef which
indicates it Linux specific. I
only see two alternatives:
+ change the errno returned (probably best since
it would be POSIX-ically correct and easier)
+ patch newlib to make these Linux-isms available.
I am pretty happy changing EBADRQC to EINVAL but
I don't know what ENOTBLOCK should change to.
Attached is a patch which shows where these are.
Thoughts?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20090611/74c71856/attachment.ksh>
