Newbie to RTEMS: ADA support issue
Ángel
leadzeppelin at gmail.com
Sun Jun 14 14:07:18 UTC 2009
Hi,
I have successfully installed the prebuilt tools set and downloaded the CVS.
My problem is that the configure script does not recognize the --enable-ada
option, as indicated in http://www.rtems.com/wiki/index.php/RTEMSAda:
$ ../cvs/configure --target=i386-rtems4.10 --enable-rtemsbsp="pc386"
--enable-ada --enable-option-checking | grep WARNING
configure: WARNING: unrecognized options: --enable-ada
configure: WARNING: unrecognized options: --enable-rtemsbsp, --enable-ada
configure: WARNING: unrecognized options: --enable-ada, --with-target-subdir
Without --enable-ada option I have successfully installed RTEMS and built
the C examples.
Thanks in advance.
URL: <http://lists.rtems.org/pipermail/users/attachments/20090614/3b7e3971/attachment.html>
