Newbie to RTEMS: ADA support issue
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jun 15 20:42:33 UTC 2009
Ángel wrote:
> Hi,
> I have successfully installed the prebuilt tools set and downloaded
> the CVS.
> My problem is that the configure script does not recognize the
> --enable-ada option, as indicated in
> http://www.rtems.com/wiki/index.php/RTEMSAda:
I think the --enable-option-checking is making each "sub-configure" script
tell you that it doesn't process that option. It really only means when
you are
in directory X, --enable-XYZ is being ignored. No big deal.
--joel
> $ ../cvs/configure --target=i386-rtems4.10 --enable-rtemsbsp="pc386"
> --enable-ada --enable-option-checking | grep WARNING
> configure: WARNING: unrecognized options: --enable-ada
> configure: WARNING: unrecognized options: --enable-rtemsbsp, --enable-ada
> configure: WARNING: unrecognized options: --enable-ada,
> --with-target-subdir
> Without --enable-ada option I have successfully installed RTEMS and
> built the C examples.
> Thanks in advance.
