Ada support in RTEMS, was: Re: Newbie to RTEMS: ADA support issue
Simon Clubley simon.clubley at googlemail.com
Fri Jun 19 12:21:54 UTC 2009
On 19/06/2009, Ralf Corsepius <ralf.corsepius at rtems.org> wrote:
>  I guess you won't like what I will say now:
>  My advice: Forget about Ada and forget about RTEMS/Ada.
I know that over the years you have expressed annoyance at the issues
involved in building gcc with Ada support. However, the above is a
more stronger comment than I remember you making previously. :-)
Are there any actual plans to drop Ada support in RTEMS ?
Are the vast majority of RTEMS users using C/C++ these days or are
there a significant number of Ada users ?
Thanks,
Simon.
Simon Clubley
