Debian-host build error...
Ian Caddy ianc at goanna.iinet.net.au
Wed Jun 24 15:26:46 UTC 2009
Hi Ed,
I am not really sure, but do you have any more details?
Such as when the error occurred, I assume during configure?
If so, did you look at the config.log output to see if it gave any clues
as to why it failed the check for being able to build executables?
regards,
Ian Caddy
Ed Sutter wrote:
> Folks,
> Didn't get any responses on this, so I figured I'd try again...
> When I reported this error, I was using pre-built tools from:
>     http://www.rtems.org/ftp/pub/rtems/linux/4.9/redhat/el5/i386/
> then the other day I started over using:
>     http://www.rtems.org/ftp/pub/rtems/linux/4.10/fedora/10/i386/
> The exact same error occurred, so I'm still clueless.
> Even the "remotest" of suggestions at this point would not be in vain
> (yea, I'm begging) :-( otherwise, I suppose I have to hunt down a different
> Linux box (non-debian) to isolate this problem.
> Thanks,
> Ed
> Ed Sutter wrote:
>> Folks,
>> I'm walking through the quick-start procedure for building the
>> BF537Stamp BSP.  My development host is Debian, and I've gotten
>> to the point (on the quick-start page) where it mentions the error:
>> * If you experience a "C compiler cannot create executables" error,
>> * try fixing your compiler by getting libc-dev
>> I ran apt-get install libc-dev and got the following message:
>> * root:apt-get install libc-dev
>> * Reading package lists... Done
>> * Building dependency tree... Done
>> * Note, selecting libc6-dev instead of libc-dev
>> * libc6-dev is already the newest version.
>> * 0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
>> Anyone working with a Debian host that has had (and overcame) this
>> problem?
>> Thanks
>> Ed
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
> No virus found in this incoming message.
> Checked by AVG - www.avg.com
> Version: 8.5.375 / Virus Database: 270.12.90/2198 - Release Date: 06/23/09 17:54:00
