Max messages in Message Queue
Samuel Bitton S.Bitton at sstl.co.uk
Mon Jun 15 16:06:02 UTC 2009
I have a local message queue defined with the maximum number of messages
set to 100 and the max size for each message set to 33 bytes.
All is fine so far. But when I try to increase the max number of
messages to 500 I get an RTEMS_TOO_MANY error.
In the manual I can't find a configuration constant that would limit the
size of message queues.
I've tried increasing the task stack size accordingly but no luck.
Any suggestion as to what my might the source of my problem?
Many thanks
Sam
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
